Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » Plusnet Network and Technical Issues » Peak and Off Peak Speeds - Post HERE!
Pages: 1 ... 13 14 [15]
  Print
Author Topic: Peak and Off Peak Speeds - Post HERE!  (Read 129313 times)
micklittle
« Reply #210 on: December 30, 2006, 12:51:01 am »
 angry
Bad and Bad and Bad   wether peak or off peak  Still Bad
Nothing but Bad here at present
wildmind
Guest
« Reply #211 on: December 30, 2006, 10:15:13 am »
can you provide the results we have asked for? simply commenting that it's bad without any indication of what is bad or wether it's your line stats etc aint too useful Wink
annie1
« Reply #212 on: January 07, 2007, 07:59:12 pm »
OK - There are several threads floating around and I figured it would be good to try and compile a single list of peoples speeds during Peak hours and Off Peak as well.
Could I please ask that discussion about speeds continue in other threads but we simply report speed tests as detailed below in this one so that the network guys can review this and get a picture of what is happening.
For consistency in all results could we all post the following info:
1) The Time the tests were taken and the Product you are on.
2) The Gateway in use (this can be found by visiting http://usertools.plus.net/@gateway)
3) A tracert to bbc.co.uk
4) Speedtests taken from http://www.speedtest.net using the Derby and the London Servers (post the images using the links they provide)
5) Using either DUMeter or NetMeter (setup exe linked) show the graph when downloading the PUG Al Wyse Interview (it's sat on our server and if we all download the same file it should give a consistent image - remember to clear your cache before downloading this if you have already watched it - which I'm sure you will have done Wink)
6) Post Router stats / synch speed where possible!
7) Also post any other information that may be relevant.
For the sake of collating info - any posts off topic will be moved elsewhere. I just think that it will be good to get as many people to provide as much info as possible - all relating to the same set of tests.
19.54
PlusNet Broadband Premier Option 1 (Monthly Contract, No Modem)
Juniper 3
Trace Attached
http://www.speedtest.net/result/72323110.png
I have to say the speeds are bad compared with my alternative ISP (http://www.speedtest.net/result/72311520.png) taken just 30minutes earlier.
Regards
Annie
« Last Edit: January 07, 2007, 08:07:56 pm by annie1 »
JBailey
« Reply #213 on: January 10, 2007, 12:41:48 pm »
Annie,
There's no way you can compare the service you are getting with us to your other service provider.  Are you using SDSL/LLU for your alternate?
Kind Regards,
James Bailey
Complaints Manager
annie1
« Reply #214 on: January 10, 2007, 05:44:26 pm »
Annie,
James
My alternative is a 2Meg line via WiMax (an antenna on the roof) whereas my PlusNet connection is supposedly 7.6Meg.
I tend to use my WiMax connection with the laptop(s), when my university based kids are home they use this connection as its via a router.
I'm interested to know why you think I can't compare the two?
Annie
JBailey
« Reply #215 on: January 11, 2007, 02:28:19 pm »
Annie,
Because it's not an IPStream service. It's a completely different type of internet connection.
Kind Regards,
James Bailey
Complaints Manager
tangey
« Reply #216 on: January 15, 2007, 08:25:36 pm »
Experiencing terrible thruput recently.
time of tests 19:55 -> 20:05 approx 15 January 07
sync speed
7136 down 448 up interleaving is on
MSR=6000
gateway = pte-ag1
Tracert to bbc.co.uk
Tracing route to bbc.co.uk [212.58.228.155]
over a maximum of 30 hops:
  1    16 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2    49 ms    52 ms    53 ms  lo0-plusnet.pte-ag1.plus.net [195.166.128.64]
  3    50 ms    48 ms    48 ms  ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
  4    50 ms    51 ms    49 ms  ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1]
  5    51 ms    53 ms    49 ms  gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
  6    52 ms    51 ms    50 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
  7    49 ms    49 ms    49 ms  212.58.238.133
  8    50 ms    49 ms    48 ms  212.58.238.33
  9    52 ms    51 ms    50 ms  pos6-0.rt0.mh.bbc.co.uk [212.58.239.30]
 10    51 ms    50 ms    51 ms  virtual0.mh.bbc.co.uk [212.58.228.155]
downloading the interview file
« Last Edit: January 15, 2007, 08:30:19 pm by tangey »
tangey
« Reply #217 on: January 16, 2007, 12:07:06 am »
....and yet a couple of hours later, I noticed a significant speed up.  I now tested it 4 hours after my previous test I find
(time of testing....around 11:50pm  15th Jan)
  1     8 ms    99 ms    99 ms  dsldevice.lan [192.168.1.254]
  2   355 ms   194 ms    49 ms  lo0-plusnet.pte-ag1.plus.net [195.166.12
  3    49 ms    48 ms    49 ms  ge0-0-0-403.pte-gw1.plus.net [84.92.4.1]
  4    49 ms    49 ms    49 ms  ge0-0-0-22.ptn-gw1.plus.net [212.159.4.1
  5    50 ms    50 ms    48 ms  gi1-1-22.ptn-gw5.plus.net [212.159.4.6]
  6    49 ms    49 ms    50 ms  rt0.thdo.bbc.co.uk [212.58.239.25]
  7    49 ms    49 ms    50 ms  212.58.238.133
  8    49 ms    49 ms    49 ms  212.58.238.33
  9    51 ms    49 ms    50 ms  pos6-0.rt0.mh.bbc.co.uk [212.58.239.30]
 10    50 ms    49 ms    51 ms  virtual0.mh.bbc.co.uk [212.58.228.155]
and the downloading file now flies down....
tangey
« Reply #218 on: January 16, 2007, 09:08:38 pm »
Is this thread still active, or were my two speedtest posts yesterday just me wasting my time ? If its not serving any further purpose, just remove it.  I would like some comments from someone in the know, if the difference in speeds and response between my 8pm tests (when the connection felt slower than my old ISDN line) to 12pm (which felt fine) are not the "expected" norm.  as of 8:30pm this evening, I fine my connection is like treacle, and yet my modem etc indicates everything is as before.  usertools exchange checker shows my exhange as green. Besides the speed difference, the one thing that stands out for me is that the ping time stated by the speedtest.net site is 3 times slower at bad times. Heres another test done just now, and again ping time is in the 150ms range.
« Last Edit: January 16, 2007, 09:12:23 pm by tangey »
fredor
« Reply #219 on: February 04, 2007, 07:36:27 pm »
Premium Account
19:20 4th Feb 2007
Line stats
Code:
Mode:                   G.DMT
Channel:                Interleave
Trellis:                ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):       16.6            11.0
Attn(dB):       15.5            20.5
Pwr(dBm):       18.4            12.3
Max(Kbps):      2784            768
Rate (Kbps):    2496            448
traceroute
Code:
traceroute to www7.rbsov.bbc.co.uk (212.58.227.77), 30 hops max, 46 byte packets
 1  192.168.0.1 (192.168.0.1)  1.478 ms  0.480 ms  0.417 ms
 2  lo0-plusnet.ptn-ag1.plus.net (195.166.128.123)  42.003 ms  44.106 ms  39.869 ms
 3  ge0-0-0-103.ptn-gw1.plus.net (84.92.3.17)  43.162 ms  44.812 ms  43.031 ms
 4  gi1-1-22.ptn-gw5.plus.net (212.159.4.6)  41.953 ms  42.144 ms  41.866 ms
 5  rt0.thdo.bbc.co.uk (212.58.239.25)  39.980 ms  41.137 ms  41.827 ms
 6  212.58.238.149 (212.58.238.149)  40.943 ms  41.146 ms  40.896 ms
 7  212.58.238.161 (212.58.238.161)  41.152 ms  43.159 ms  39.876 ms
 8  www7.rbsov.bbc.co.uk (212.58.227.77)  42.125 ms  40.168 ms  40.824 ms
http://speedtest.net/result/82299739.png[/img]]
I have been waiting for nearly 2 weeks to have interleaving turned off but so far PN have not managed it !!
  Print
Jump to:
