Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » The PUG Place » email revealed when using reported post
Pages: [1]
  Print
Author Topic: email revealed when using reported post  (Read 1321 times)
Oldjim
« on: January 26, 2015, 11:30:04 am »
You have the same default text as the main Plusnet site - probably should be sorted
spraxyt
Usergroup Member
« Reply #1 on: January 26, 2015, 07:12:00 pm »
Are you referring to the text on the second line of the reporting pop-up (attached)?
That reflects reality on this forum (in the notification email received), though full members can view email addresses anyway.
Pages: [1]
  Print
Jump to:
