Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » The PUG Place » "recent posts"
Pages: 1 [2]
  Print
Author Topic: "recent posts"  (Read 7924 times)
dhookham
Administrator
« Reply #15 on: October 04, 2014, 06:49:27 pm »
Still getting "an empty window", odd that it works for you, but maybe your set-up is more sophisticated.
lol
I tested it on an old Eee netbook - the only machine that had Windows 7 on it. It uses Avast, so sophistication isn't quite the word I'd use Tongue
The only other thing that crossed my mind was whether you had javascript turned off or blocked, but I'd imagine more things would be an issue than just the icon popup if that were the case.
It's the PlusNet Way
Penny
WWW
« Reply #16 on: October 04, 2014, 06:58:11 pm »
lol
lol
... as to javascript, I've no idea whether it's enabled or not (and no idea where to look to check that, either : | ) but wouldn't that affect Firefox equally, given both are on the same PC (?)
Regards,
Penny.
Penny Rollo       Force 9 from 17/02/98       PlusNet from 2000 onwards
Project HappyChild - free maths worksheets, free French-English
worksheets and 12 other languages http://www.happychild.org.uk
personal site www.pennymidasrollo.plus.com
spraxyt
Usergroup Member
« Reply #17 on: October 04, 2014, 07:53:49 pm »
@Penny,
If you visit https://www.whatismybrowser.com/is-javascript-enabled it will tell you (on the first few lines) if JavaScript is enabled in your browser. I think the on/off setting can be different in each browser.
David
Penny
WWW
« Reply #18 on: October 04, 2014, 09:40:33 pm »
thank you : )
... and yes, it is enabled.
in both IE11 and FF 32.0.3.
Intrigued, now : )
Just looked at "inspect element" on each page, both have <a href="javascript:moreSmileys();">[more]</a>
but the [more] doesn't display in the FF visible element-text except if I copy-and-paste it here.
Right-clicking the '[more]' visible-text-on-the-page and selecting 'properties' for IE gives:
Protocol - Unknown Protocol;  Type - Not Available;  Address URL - javascript:moreSmileys();
... FF doesn't have a 'properties' option on right-click.
As you're aware I don't know the first thing about javascript : )  is the factor "unknown protocol" somehow relevant?  I went looking for unknown protocol javascript on Google - there are a lot of related posts but nothing I understood, particularly : /
Regards,
Penny.
dhookham
Administrator
« Reply #19 on: October 05, 2014, 12:10:22 pm »
Another thought is that the javascript generates a popup window - perhaps AVG or something else is blocking popups (or their content, at least)?
Penny
WWW
« Reply #20 on: October 06, 2014, 05:25:46 pm »
... perhaps surprisingly, the pop-up factor did actually occur to me, before, so I went looking and discovered usergroup.plus.net wasn't specifically on my list of "allowed" sites.
... though logically if a blank pop-up was appearing I didn't understand why just its content should be missing.
Anyway I added 'usergroup.plus.net' (it wouldn't accept a separate 'usergroup.plus.net/forum' but I assume that's because the former permits anything within the whole of usergroup.plus.net).
It didn't make a scrap of difference : /  still an empty window.  I don't think I can hang this one on AVG Free (has never caused any issues whatsoever in the past).
graphics lol from http://usergroup.plus.net/forum/Smileys/kitzemotes/lol.gif
from "more" - http://usergroup.plus.net/forum/Smileys/kitzemotes/congrats.gif
I can see the congrats graphic "separately" in IE11 (ie if called up directly) - struggling a bit now to understand why I wouldn't be able to see it (or anything else) in the pop-up window on IE11.
Having said that, I can't now see 'congrats' in FF, either, neither on the standard bar above where the post text goes, nor in the 'more' pop-up window : /
I give up - it doesn't matter - lol   this is clearly just not meant to be : /
spraxyt
Usergroup Member
« Reply #21 on: October 06, 2014, 06:51:24 pm »
Hi Penny,
I've no idea whether the following suggestion is relevant since it's related to a question on getting blank tabs. But changing this setting fixed that user's problem.
I went to Tool, internet options, advanced, and under security clicked Enable Enhanced Protection Mode.
David
Penny
WWW
« Reply #22 on: October 06, 2014, 07:21:11 pm »
... actually, it was : D
and it worked   lol   same set as FF, now both including congrats  it's been a random sort of day : /
Thanks to everyone for all the ideas, really never thought this had any prospect of getting sorted, appreciate the help  cheers
Regards,
Penny.
spraxyt
Usergroup Member
« Reply #23 on: October 06, 2014, 07:42:57 pm »
Amazing, thumbup. Now a few more of these cheers then we can dance
David
Penny
WWW
« Reply #24 on: October 06, 2014, 08:12:28 pm »
lol
... as a footnote, "recent posts" seems to be working perfectly again as well.
Everything has ended up rather better than expected : D
Pages: 1 [2]
  Print
Jump to:
