Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » The PUG Place » Can't connect to usertools IRC
Pages: [1]
  Print
Author Topic: Can't connect to usertools IRC  (Read 5066 times)
Sophira
« on: October 20, 2013, 10:51:50 am »
Hi!
I'm a new poster, so my apologies for not introducing myself in a separate post first. My name's Sophie and I'm living in Scotland. Smiley
I can't seem to connect to the IRC server at usertools.plus.net. I am doing so from a PlusNet connection, 91.125.157.168 (168.157.125.91.dyn.plus.net). I just get a "Connection timed out" error when I try.
I can connect via the CGI-IRC client, but I'd rather use my own client. Does anyone know what might be up?
jelv1
« Reply #1 on: October 20, 2013, 10:59:21 am »
I've just connected using ChatZilla (from 80.229.*.*) without any problem.
If you are not on a static IP I suggest trying a disconnect/reconnect until you are on a different IP range and then try again.
« Last Edit: October 20, 2013, 11:01:42 am by jelv1 »
jelv
spraxyt
Usergroup Member
« Reply #2 on: October 21, 2013, 12:34:53 am »
I think the list of Plusnet IPs built into the IRC server software is somewhat dated. The 91.125.*.* range which was originally MAAF is probably not included. Disconnecting and reconnecting to try to get on a different range is suggested.
Oldjim
« Reply #3 on: December 07, 2013, 10:26:38 am »
Still not fixed http://forums.thinkbroadband.com/plusnet/f/4286382-plusnet-irc-still-a-farce.html
Pages: [1]
  Print
Jump to:
