Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » Plusnet Customer Service Issues » Referral section of member centre
Pages: [1]
Author Topic: Referral section of member centre  (Read 1881 times)
« on: November 30, 2012, 05:28:59 pm »
I'm just about to send a referral email via the member centre and noticed that it says:
2. Refer friends via word of mouth
When you refer a friend via word of mouth, make sure they know how to indicate that you referred them.
During signup they will be asked for referral details, in order to complete this they will need to know your username and ISP.
Your username is: xxxxx  Your ISP is: PlusNet
My ISP is Force9 and I know from previous experience that I almost didn't get the referral because when the new customer mentioned my username CS said that they couldn't locate it (unsurprisingly).  I had to call in to explain.
Should this be amended perhaps?
Force 9
Joined 03 June 2004
Usergroup Member
« Reply #1 on: November 30, 2012, 11:25:10 pm »
Well spotted, it incorrectly says PlusNet for me too. This definitely is something that needs to be sorted out.
The click through links seem to be based on Service ID (the correct one for me) so those should go to the right place.
Pages: [1]
Jump to:
