Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » Plusnet Customer Service Issues » Broadband speeds
Pages: [1]
  Print
Author Topic: Broadband speeds  (Read 3154 times)
trudibasso
« on: February 12, 2010, 01:31:21 pm »
With falling speeds on my BT line with madasafish, never good at maximum 1.5, tried to get some info first from Bt sales then online. Bt informs me that I most certainly can get up to 20 and on line maximum 1.5. Nowhwere can I find information when my Kings Lynn exchange will be upgraded. The information on the plusnet site is total gobbledegook. Does anyone have any more precise information?
spraxyt
Usergroup Member
« Reply #1 on: February 12, 2010, 04:35:46 pm »
It already is enabled according to the information on the Usertools checker
http://usertools.plus.net/exchanges/ and on the Plusnet list
http://community.plus.net/21cn-exchange-availability/
You need your exchange code (EAKLN) from the first link to find the status in the latter.
Entering the attenuation from your router stats into Kitz's calculator
http://www.kitz.co.uk/adsl/max_speed_calc.php
will give you theoretical performance information for your line on ADSL1 and ADSL2+.
Hope this helps
David
trudibasso
« Reply #2 on: February 13, 2010, 01:18:30 pm »
Thanks for that David. seems I should be getting better than i've got! Must be the aluminium joints in the copper wires John
maccman
« Reply #3 on: March 05, 2010, 03:41:58 am »
Hi
My speeds seem to have dropped from around 5mb to about 1.5/6mb
i see that the Rock Ferry exchange is scheduled for upgrade work in feb but it was last updated in January
i have put in my original router and there's no noticeable difference.
could you check if this upgrade work may be the problem?
David
spraxyt
Usergroup Member
« Reply #4 on: March 05, 2010, 01:34:22 pm »
According to the Plusnet list
a 21CN service is available to those on the Rock Ferry (LVROC) exchange. However the upgrade to this up-to-20Mbps service is available only to those on the Plusnet Premium and Plusnet Pro products. Plusnet have yet to announce their policies with regard to 21CN and legacy products.
However upgrading an exchange for 21CN should not have any effect on 20CN services. These remain as they are so your speed problems should be unconnected with this.
Have you raised a ticket concerning your problems (https://faults.plus.net/)?
Note that I am a customer just like yourself so have no access to any information concerning your account.
David
maccman
« Reply #5 on: March 06, 2010, 07:41:06 pm »
i have now raised a ticket
Dave
Pages: [1]
  Print
Jump to:
