Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » Plusnet Customer Service Issues » Is there a problem with the DNS servers - solved I think
Pages: [1]
  Print
Author Topic: Is there a problem with the DNS servers - solved I think  (Read 1541 times)
Oldjim
« on: September 05, 2008, 11:26:02 am »
Suddenly I can't get to many sites using
Primary DNS:   212.159.6.10
Secondary DNS:   212.159.6.9
Edit
Added an opendns server to the router and it didn't help so disconnected and reconnected from Plusnet and it worked.
Changed back to Plusnet servers and disconnected/reconnected and it still worked
Note I didn't initiate a resynch only disconnected/reconnected from Plusnet
« Last Edit: September 05, 2008, 11:55:02 am by Oldjim »
Pages: [1]
  Print
Jump to:
