Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » Plusnet Customer Service Issues » failing connection
Pages: [1]
  Print
Author Topic: failing connection  (Read 1810 times)
stathe
« on: August 14, 2006, 08:41:03 pm »
My connection has been failing for some months now , is fine for the odd day or so B.T have visited and said there was a fault on the line,after that it was fine for a week or so, but now it is as bad as ever  Plusnet ocasionaly add to my fault history but nothing seems to get done I have raised fault ID 19477658 from 25May until 7Aug and 20052179 from 12 Aug to date. It will be expensive for me to move . I dont think I am getting the service I should expect. Plusnet are very good at takeing my direct Debit
Pages: [1]
  Print
Jump to:
