Home   Help Search Groups Login Register
You are not logged in. To get the full experience of these forums, we recommend you log in or register
Plusnet Usergroup » All Users - The Open Forum » Plusnet Customer Service Issues » POP3 dead
Pages: [1] 2
  Print
Author Topic: POP3 dead  (Read 11800 times)
dgdclynx
Guest
« on: June 11, 2006, 09:04:58 am »
Just to say mail.plus.net is down in case PN are not reading p.s.c-f
mr_chris
« Reply #1 on: June 11, 2006, 09:47:03 am »
According to a post in this thread - the timeouts started happening at 08:10 - that's over ONE AND A HALF HOURS ago.
WHERE IS THE SERVICE STATUS?
So much for 24/7 Networks coverage eh?  angry
Chris
Ultra
WWW
« Reply #2 on: June 11, 2006, 09:51:43 am »
Thanks for the info...
I tried using IMAP access (from Thunderbird) a while back but quickly gave up...
I never bothered to query it with anyone (via channel) as it seemed to be "par for the course".
I note the "status" indicators show no problem with e-mail at the moment...
Wonder how long it will take for that to change ?
Ultra
WWW
« Reply #3 on: June 11, 2006, 09:52:55 am »
mr_chris - I guess it depends on how many reports of a fault are seen...
kitz
WWW
« Reply #4 on: June 11, 2006, 09:57:21 am »
I tried contacting CS to ask why there was no SS report on this.
Seems like the phone system is also down.
Dont forget the Geeks!
kitz 2005
mr_chris
« Reply #5 on: June 11, 2006, 09:58:33 am »
NetGuy - guess so  rolleyes
Chris
kitz
WWW
« Reply #6 on: June 11, 2006, 10:03:07 am »
My records show that the first hiccup showed at 7.15am this morning..  but its been totally dead since 8.10.
kitz 2005
kitz
WWW
« Reply #7 on: June 11, 2006, 10:44:23 am »
Service Status Report
Due to our planned maintenance, our webmail, and email platforms are experiencing intermittent problems.
These issues will be resolved when the maintenance completes.
Planned maintenance???
What planned maintenance would that be
kitz 2005
pcsni
WWW
« Reply #8 on: June 11, 2006, 11:34:02 am »
Unless Fridays server move to the new colo dragged on a bit longer ?
That being the case, there should have been a SSA detailing the delay though.
kitz
WWW
« Reply #9 on: June 11, 2006, 11:57:11 am »
I thought all the moves had been completed sucessfully last friday.
kitz 2005
aetos
WWW
« Reply #10 on: June 11, 2006, 12:42:47 pm »
12.41 server still appears down, why was maintance (if schedualed) not arranged for off peak usage ??
MArk huh
Colin
Usergroup Member
WWW
« Reply #11 on: June 11, 2006, 01:13:47 pm »
It's randomly up and down from what I can tell... I have a script checking email which is randomly succeeding but more often failing.
Colin Ogilvie
Plusnet Usergroup Member
Using: Plusnet Extra
pcsni
WWW
« Reply #12 on: June 11, 2006, 03:03:44 pm »
Not sure kitz. Last mention was the warning SSA on Thursday 8 giving notice of the works,link but no update either way followed.
dtomlinson
Plusnet Staff
« Reply #13 on: June 11, 2006, 05:57:25 pm »
Mail should be all OK now, I've just updated status saying it's now fixed.
Regards,
Dave Tomlinson
PlusNet Support
Oldjim
« Reply #14 on: June 11, 2006, 06:08:38 pm »
But it isn't - still getting problems
Pages: [1] 2
  Print
Jump to:
